ir7095 DADF-J1 double side 2-2 shrink vertically
  • jiongpao
    • May 2009
    • 413
    Hi, from the images above the result from 2-2 shrink down about 1cm when using ADF. Single sided and using platen glass are fine.
    I adjusted the DADF y-axis in service mode and it only work for copying single side. But the result still the same for back to back.
    So i manually adjusted DADF original tray and it doesnt effect much
    I also cleaned the sensors and dust around but still no luck.
    From what i know this problem happen after changed the whole unit of DADF-J1 from other machine. But how does it cause so much shrink till it impossible to manually adjust from DADF original tray?
    Can some one please help me.
  • roller
    • 26
    Re: ir7095 DADF-J1 double side 2-2 shrink vertically
    DADF J-1 goes with ir600, ir8500, ir85, ir105... but not with ir7095.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5013
      [ATTACH=CONFIG]17269[/ATTACH]
      M1 and Q1 if i remember
      • jiongpao
        • May 2009
        • 413
        Re: ir7095 DADF-Q1/M1 double side 2-2 shrink vertically
        Yes sorry for misinformation and thank you for correcting me. Normally i referred to J1 SM because they almost the same.
        • roller
          • 26
          Try to adjust ADJ-Y-DF and ADJ-Y-FX.
          ir7095.pdf
          • spectraindo
            • May 2008
            • 313
            Copies shrink has to do with LA-SPEED adjustment.
            Try FEEDER - ADJUST - LA-SPEED
