Canon ir2270
  • mramlawi
    • Jul 2011
    • 838
    Canon ir2270
    Dear all ,
    kindly i have a problem on the ir2270 which was workin fine and suddnely started to jam ,its jams as the figure show on the copier located on the right cover but when i open the cover theres nothing ,just hearing that the paper is tryin to exit from drawer but it didnt ,some times jams when its exiting the drawer
    what i didnt
    i changed the feed assembly for 1st unit
    i cleaned the sensor which located on the right door(BYpass door)
    still occur same problem.!!!
    i enter the service mode Jams ,the jam no is 101 as the manual said it 1st drawer assemble sensor !!
    by the way also at the same machine when turn the machine on and canon bar take long time to gives the menu ?
    guess its an HDD problem or what ?
    thanks ,
    any clues ?? thanks anw
    Distinguished road makes you jewel in rough
  • ernesto
    • Oct 2011
    • 430
    Re: Canon ir2270
    Originally posted by mramlawi
    Dear all ,
    what i didnt
    thanks ,
    you can try to change a3 drawer to a4 and check if the problem is still going on...?
    • mramlawi
      • Jul 2011
      • 838
      Re: Canon ir2270
      i already made this still same problem ,i solve the problem today and i change the one way for the feed assembly and it works
