CANON C-IR2016
  • Alphonse
    CANON C-IR2016
    HI, my copier canon c-ir2016 is demanding a DEPT ID & PWD.
    with out it the copier is dead. pls I need help on how to unlock.
    some one manipulated and inserted a dept ID & PWD and now
    no other action can be executed due to the message above.
  • montana
    • Aug 2008
    • 392
    Re: CANON C-IR2016
    hi....you have to get in service mode and clear the password............
      • 16083
      Re: CANON C-IR2016
      in Service Mode=
      Press the operation panel user mode *key, release >then press 2 key,>release>then press 8 key,>release > then press user mode *key in this order./ select #CLEAR
      #CLEAR
      PWD = Use it to clear the system administrator's password.
      To exit service mode , press the user mode * key to return to standby mode.
      • Alphonse
        Re: CANON C-IR2016
        Originally posted by teckat
        in Service Mode= Press the operation panel user mode *key, release >then press 2 key,>release>then press 8 key,>release > then press user mode *key in this order./ select #CLEAR #CLEAR PWD = Use it to clear the system administrator's password. To exit service mode , press the user mode * key to return to standby mode. then post this____[ATTACH=CONFIG]17280[/ATTACH]
        Thanks but I have followed the steps carefully to no avail with the photocopier when I press the *key it gives me but a beep sound same with #key. HOW DO I GET ACCESS INTO SERVICE MODE? WHEN YOU BOOT THE COPIER ITS THE DEPT ID & PWD THE APPEARS
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5013
          Re: CANON C-IR2016
          Press user mode key add func.jpg not *.
          I believe you are not the one who won't to manipulate.
            • 16083
            Re: CANON C-IR2016
            are u are hitting the wrong * key ?? beep because u are hitting the Tone Key
            u need to hit the Additional FUNCTION KEY (*) /or USER MODE KEY ----different models name it either one-
            SEE PICTURE
            /CLICK TO ENLARGE
            • Alphonse
              Re: CANON C-IR2016
              SEE PICTURE
              /CLICK TO ENLARGE
              Hello,Hello, this is wonderful. I enjoy you Tech advise.
              All done and working properly. Thanks very much
                • 16083
                Re: CANON C-IR2016
                Thanks, I send u your bill
                • zoraldinho
                  • Mar 2008
                  • 5013
                  Re: CANON C-IR2016
