change paper size
  • margic brian
    • Jul 2012
    • 97
    [Misc] change paper size
    hello guys,
    my client has an ir2016 copier but she always complains that whenever she is copying the copier demands for a paper size change. and when you change the orientration the same problem appears all over again.
    i have tried all means but the problem is persisting what could be the problem.
    your assistance will be highly appreciated
    thanks
    margic brian
  • akm
    • Sep 2012
    • 155
    Re: change paper size
    Dear Sir,
    you can try to clean the registration clutch if not correct the problem change the clutch
    thanks
    • mjarbar
      Originally posted by akm
      Dear Sir,
      thanks
      The registration roller as well...
      Does the machine give any jam codes?
      • teckat
        • 16083
        Originally posted by margic brian
        hello guys,
        thanks
        margic brian
        u mean off the Glass or using DF ??
        is this on all paper sizes ??
        Check that the Country Code has been set. Enter Service Mode> #CLEAR >OK > TYPE > OK > select the Country.
        1.Using the arrow keys select "# Clear" then press the OK key
        2.Using the arrow keys scroll to "TYPE" then press the OK key
        3.Using the arrow keys, select the country/region type that conforms to the communication standard of where the machine is located.
        4.With the country/region displayed, press the OK key. When "Please Wait" disappears, the selected country/region type takes effect.
        for Incorrect paper size message or pickup delay jam
        replacing the 27T/50T Gear (FB6-1633-000) with 40T/50T Gear (FC6-4390-000) in the cassette 1 Paper Pick-Up Assembly corrects the problem.
        • Cabo
          • Aug 2012
          • 41
          I have this problem on copier who has made more than 500.000 copies.Replace flag sensor pre-regist FC6-4310-000.
          • margic brian
            • Jul 2012
            • 97
            Dear Sir,
            thanks
            thanks akm for that advice i tried that and it worked
            • margic brian
              • Jul 2012
              • 97
              thanks to all you guys for that advice its been help full atleast i know what to do
              • margic brian
                • Jul 2012
                • 97
                machine does n0t give any jam codes
