Magenta missing in the center
  • V-P
    • Apr 2011
    • 679
    Canon iRC3580
    Magenta is missing only in the center as you will see in the attachment.
    Life of drums is 50%. I did stir the toner twice and cleaned the sensors.
    Can it be caused by 3-rd party toner ? I have no idea what the customer is using.
    If not - by what ?
    Thnx...
  • teckat
    • 16083
    Re: Magenta missing in the center
    Originally posted by V-P
    Canon iRC3580
    If not - by what ?
    Thnx...
    [ATTACH=CONFIG]17303[/ATTACH]
    Swap the Lasers / to see if it travels
    • V-P
      • Apr 2011
      • 679
      I was somehow hoping you would suggest smth "faster".
      Anyway I already manually checked the mag unit. When I rotate the drum by hand I can see that in the middle it looks like slightly yellowish.
      Or more yellowisher than the edges.
      thnx
      • r3d343420
        • Aug 2012
        • 55
        I agree with Teckat. looks like a bad or dirty laser for magenta. Does the developer look like it is covering the entire mag roller? Good luck
        • Herrmann
          • Jan 2006
          • 792
          X3... Debris on the M Laser Glass, or Laser Error
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5009
            I bet on faulty drum.
            • V-P
              • Apr 2011
              • 679
              It is not the laser. I cleaned them.
              I put an old magenta unit inside and the problem went way.
              So it was the magenta unit. Will check tomorrow why.
              thnx
              • zoraldinho
                • Mar 2008
                • 5009
                • V-P
                  • Apr 2011
                  • 679
                  A bit of update on that case:
                  We replaced the magenta unit and now the copier printouts look fine.
                  The problem is that I never had a drum fail like that before, and I have a strong feeling that customer is using 3-rd party toner.
                  But I cannot prove it.
                  Is there any way to tell by looking at SM (like density values or smth) ?
                  I don't want to replace the other one same way as this one.
                  • teckat
                    • 16083
                    Drum Density values change when toner is added from hoppers by machine signals
                    i would demand to see the OEM BOX & or purchase bill if there is a contract involved---if this is a pay by call for service & parts u have no leg to stand on-
                    if u personally wrote a contract for customer>>>
                    if use of non-Canon oem toner/ & or drums is written in contract as being a violation to void such contract/ not much u can do--- this all depends on Country
                    or>>
                    if you work for a Canon Authorized dealer / u then have a case> damage to printer parts from non oem toner/starter can result in a automatic void contract/ + customer needs to pay for those parts replaced
                    • V-P
                      • Apr 2011
                      • 679
                      No the copier is not on contract. But we (the company) sold him the first set of drums.
                      It is more of a moral case rather than obligatory.
                      "you sold us genuine drums which turned out to be as good as 3-rd party stuff" - this kind of reasoning.
                      That customer won't show me the bills, but it is my suspicion he is using 3-rd party toner.
                      I gave a look at his COPIER>DISPLAY>DENS
                      and DENS M was about -8% while the other colors approx. 0%.
                      will see how this will turn out
                      thnx for reading...
                      • teckat
                        • 16083
                        machine corrects the density
                        of individual colors (Y, M, C). It, however, varies the developing bias for BK
                        machine uses
                        the same developing bias for all colors --xcept BK
                        machine measures the toner image formed on the ITB using the patch image read sensor, and supplies
                        the drum unit so that the density will be identical to the target density.
                        so> poor patch =poor density= sometimes an error
                        if u don't get those e020 patch errors/ no proof in pudding
                        -8.0 should pop an error soon
                        DENS-Y/M/C/K
                        Calculated value of developer concentration (indicated as % off target value)
                        Appropriate values -2.0 to 2.0%
                        Note
                        Value is updated when toner is supplied after main power switch ON.
