Clearing the Dept ID & PW on CIR2880i
  • delosangeles
    • May 2008
    • 274
    Hello everyone we are working on a clients Color IR2880i and we needed to enter the Additional Functions menus but there is Dept ID and Password needed the clients key operator no longer works there and that person had User ID info. We know how to enter the service mode thru the 28 procedure but we are not sure how to disable the Dept ID function
    Thank you in advance for any help
    Trade like a tiger sleep like a baby
  • delosangeles
    • May 2008
    • 274
    Re: Clearing the Dept ID & PW on CIR2880i
    Never mind everyone, I got into "Additional Functions" thru SP accesse 28 then COPIER>FUNCTIONS>CLEAR then performed "MMI" & "PWD-CLR"
    Everyone have a great weekend and God Bless
    • teckat
      • 16083
      why did u do a MMI Clear ???
      MMI Clears following user mode setting values: u better check them
      - Backup data for copy operation panel (user-set values)
      - Common settings backup data (user-set values)
      - Backup data (except fax data) (user-set values)
      Attention:
      The setting values are cleared after the main power switch is turned OFF/ON.
      Operation method
      1) Select this item, then press the OK key.
      2) Turn the main power OFF/ON.
      if u have a Fiery connected > check if this setting was changed-----
      COPIER>OPTION<INT-FACE>IMG-CONT & set it to "3" for imagePass connection/hit OK & power off/on printer
      if no Fiery--set to "0"
      • karthiksg
        Re: Clearing the Dept ID &amp; PW on CIR2880i
        Must go to printer settings in your system and must enable the option not to prompt for pin.
        thanks to boon swan
        Attention:
        Operation method
