reset the factory settings of ir 3570
  • akm
    • Sep 2012
    • 155
    Dear Copytech,
    Pls i need to know the procedure to reset the factory settings of ir 3570
    thanks
    akm
  • Brian8506
    • 1664
    Re: reset the factory settings of ir 3570
    Before you go clearing things you should print out a "p print" so you know what the settings are now. What problem are you having?
    • akm
      • Sep 2012
      • 155
      Dear Brian8506,
      the problem that i face when i ping to ir3570 from computer the result "request time out" ofcourse i can not print the tcp/ip settings are
      correct
      thanks
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Additional Functions > System Settings > Network Settings > TCP/IP Settings >turn DHCP "ON">restart the machine.
        After that go again in TCP/IP Settings to check for IP number or you can install the driver again.
        • akm
          • Sep 2012
          • 155
          sorry sir, i make these adjustements but still not ping i want to tell you that the machine is used copier so i need toreset the factory settings
          thanks
          akm
          • Brian8506
            • 1664
            additional functions/2 and 8 at same time/ additional funcions/copier/function/clear/dc con/ok. Its not gonna help that problem but thats the procedure. Sounds like an ip address problem.
            • Herrmann
              • Jan 2006
              • 792
              on the newer mashines, you are able to reset to factory defaults from the user menu. The advantage is, that you will do no possible harm to your mashine in spite of reset the dc-con. I am not sure, if this function is availible on the ir3570 too, but you should give it a try.
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
              • Herrmann
                • Jan 2006
                • 792
                Just found the description in another thread:
                On the imageRUNNER Device (see above for supported devices), press the Additional Functions key, then,
                select the System Settings button (if assigned, you will need to enter the administrator password to
                access this menu); then select Initialize All Data/ Settings.
                Thanks to Teckat
                • arielcanon
                  • Mar 2012
                  • 106
                  Originally posted by mallusp
                  Hi,
                  First you check the Network Cable...
                  or buy a new cable or re-trim the old jacks and connect it..
                  the PING problem is not for the machine.. if ur machine shows an IP Address, then u can ping it from ur computer..
                  Check the Cables and network connections (Hub/Switch)
                  Thank u
                  it's better to check your connection directly to a PC using crossover cable. if the result is NG, it might be trouble with your network board (main board)
                  Learning never ends..
                  Never give up, where there is a wheel there is a way..
                  • teckat
                    • 16083
                    To test that the copier is functioning correctly, you can attempt to PING the loopback address 127.0.0.1. If this also generates the 'No Response From Host' message, then there may be a problem with the copier's NIC. You can try the following to troubleshoot the NIC:
                    - Reboot the copier.
                    - Re-seat the RJ45 of the network cable.
                    - Try another network cable.
                    - Re-seat the NIC in the copier.
                    - Try clearing the MMI in Service Mode on the copier. Reboot and reconfigure the copier.
                    - Try formatting the HD and reinstalling system software on the copier. Buyer Beware ----------------
                    NOTE: PC's may have firewalls running that block ping requests.
                    Verify the PC you are attempting to ping will reply to a ping from another PC on the network.
