imageRUNNER ADVANCE 8000 / 6000 Series / All
Minimizing Early failure of the Thrust Retainer Rings and/or the Bushings in the Upper Fixing Assembly
When the quantity of the Grease is insufficient or the Grease is applied in an inappropriate way, the friction
between the Upper Fixing Roller and the Bushings may generate stress in a direction to push the
Thrust Retainer Rings outward.
If this should occur, the Thrust Retainer Rings may come off from the Upper Fixing Roller or break.
see pdf------------TP12.pdf
