IRA 2020L
  • spectraindo
    • May 2008
    • 313
    Re: IRA 2020L
    I have done this and it works :
    Go to Service Mode > COPIER > OPTION > NETWORK > RAW-DATA change to 1 (no image processing).
    Turn off the machine and then back On.
    Good luck.
    • disam
      • Sep 2008
      • 64
      Re: IRA 2020L
      Good luck.
      Hi
      try also this, without changing something in the Service Mode.
      Printer Driver (only UFR II) - Driver Settings - finishing - advanced Settings - always rastering on host - Change from off to on.
      • Master General
        Re: IRA 2020L
        Good luck.
        Originally posted by disam
        Hi try also this, without changing something in the Service Mode.
        Thank you very much guys! Everything works fine. Even 120Mb JPEG on A3 printed without problems. I've tried both methods to fix problem. First in service menu, then in UFRII driver settings.
        • Benjamin98
          • Mar 2015
          • 89
          #19
          Re: IRA 2020L
          This is the latest driver version if anyone is wanting it i.e. v21.52:
          Canon UFR II/ UFRII LT Printer Driver
