ir1133iF E733-0000 error
  • macuk
    • May 2009
    • 90
    [Error Code] ir1133iF E733-0000 error
    This ir1133if is causing me problems! Customer is getting E733-000 error once or twice a day, he turns it off and then on and it disappears.
    I have reloaded software, then replaced the main controller. Error disappeared for two days then started again. I then replaced the combined controller/ power supply board and the ribbon cables in between them. Error again stopped, this time for 4 days before reappearing once again.
    The error code suggests that it is a communication problem between the two boards. As I have replaced both boards and the connections between them and upgraded software, does anyone have any other ideas?
    • 16083
    Re: ir1133iF E733-0000 error
    /// how is your outlet voltage ??
    hot>net
    net>gd---most important 0v>0.5 no more
    hot>gd
    this is usually a communication issue/ or poor>>in-correct supply voltages
    check all cable contact pins
    • macuk
      • May 2009
      • 90
      Just to update you all. The boss decided to swap out the machine for a new one. This got delivered this morning, six hours later new machine has thrown E733-000 as well!
      Seems like it maybe power after all.
