How to upgrade firmware on canon ir2520
  • ppanjj
    • Jul 2025
    Hi all, pls can someone help me how i can upgrade firmware on Canon IR2520 in user mode?
    I set my network setings in copier: IP address: 192.168.1.7
    subnet mask:255.255.255.0
    gateway:192.168.1.1
    Then i set DNS: 192.168.1.1
    then i go in user mode on last page and pres "system upgrade" buton,
    then my copier get restart and show me on screen: network download available
    and do nothing! SRY for my bad english
  • Cabo
    • Aug 2012
    • 41
    Re: How to upgrade firmware on canon ir2520
    You most download UST and firmware with canon server.Procedure is in attah.
    • toantam
      • 63
      gateway:192.168.1.1
      Dear friend!
      At first, you have to use Service Support Tool from Canon, firmware for this model...
      And Are you technician of Canon?
      Hope you can solve your problem.
      • ppanjj
        Hi, and yes im technician of Canon "toantam" and im done with using suport tool, but i heared that canon ir 2520 can update just by setting gatewey.
        THX for the reaplay.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Originally posted by toantam
          Dear friend!
          You don't need SST for this model.This model have UST (user support tool).
          Read Cabos attached file!
          • billy_we
            Hello,
            I am sorry dont meant to hijack the post but I have a similar problem. Just replaced an canon ir2520 with same model but took the feeder off the old model and connected it on the new machine. Unfortunately, didn't work and my guess is it needs a firmware update. I did all the checks under #SCAN and #FUNCTION there is power to the feeder however, it just prints blanks with lines.
            Feeder works on the old machine fine and the settings appear the same. Feeder responds to FEED-ON, FEEDER, MTR-CHK and returns OK and you here it spin and hear noise. The same is not true when connected to new machine.
            I tried to upgrade firmware but got stuck on screen: network download available IP address: *******
            Does anyone have the right tool for this? Any help would be welcomed.
            • Gbr
              • Nov 2011
              • 50
              Hello,
              I have a Canon IR 2520i, and every so often (can be multiple times a day, or can work fine for couple days and then again) displays message "network download available IP adress : 192.168.xxx.xxx (it's ip adress allocated to machine)
              Message ussually displays after it's "awaken" from standby.
              Firmware is up to date:
              Network discovery is turned off, and we performed all-clear after upgrade.
              Any ideas?
              Regards
              • igor002
                Hi
                I desperately need the newest firmware for the Canon IR2520. I don't have the Canon SST and Canon UST.
                I need firmware and User Support Tool (someone have information where i find UST? i serch via google but i cant finde )
                My mail: igor002@interia.pl
                Thanks a lot!
                Gregory
                • olegosh
                  I got the same error , I desperately need the firmware for the Canon IR2520, mail elenaaravan@gmail.com
                  • Jhn16
                    • Sep 2019
                    • 7
                    ANY ONE WHO HAVE A SYSTEM SOFTWARE/FIRMWARE FOR CAN IR 2520 PLEASE
                    LETS CONTACT THROUGH THIS MAIL:
                    johnmtingwa@gmail.com
                      CONTRIBUTORS to CTN get a quicker response... and seeing how long it's been since the person WITH the files most times this type thread is dead.
                      • Nguti
                        • Mar 2023
                        • 1
                        ANY ONE WHO HAVE THE CANON USER SUPPORT TOOL AND FIRMWARE FOR CANON IR 2520 PLEASE
                        LETS CONTACT THROUGH THIS MAIL: I AM NEED ASAP
                        roland2ndi@gmail.com
                        • copier tech
                          • 8142
                          Happy to help.
                          Please contact us via either web site below.
                          www.printerfirmware.co.uk
                          • copier tech
                            • 8142
                            contact me pls roma.gigel@gmail.com
                            Happy to help. Drop us an email.
