Ir5570 Customize Paper Size
  • zibros
    • Sep 2012
    • 31
    Is there any way to custom paper size in Ir5570.
    For example, I want to make paper size a half of F4/U2 (length : 16.5 cm x width : 21.5 cm). This paper size is not build in machine.
    Why I want to make this? because I want make booklet copy of the original size (a half of F4), and the print out booklet with use F4/U2 paper size.
    If I assume the original size is STMT, in the result there are some text will be trucked
    If I assume the original size is B5, one of the margin (up or down sides) is shifted.
    So, can we customize the paper size in the machine like we do in computer?
    thanks
    Z
