Tray Configuration for IR 7105
  • manuelubau
    • Aug 2011
    • 62
    How to change configuration of tray #3 when I place paper LTR it reads it as B5... I need to change the settings for it... how do I do it?
    Thanks,
  • teckat
    • 16083
    Re: Tray Configuration for IR 7105
    Thanks,
    Setting the Cassette
    Fit the side guide plate [1] in the hole (A4/A3) identified by the marking M [2].
    Fit the included inch block from inside the cassette so that the hole (STMT-R) of marking A [1] and the hole (LTR-R) of marking H [2] are covered.
    Be sure there is no gap.
    Perform the foregoing steps if the user is going to use AB series sheets only.
    Cassette 3
    COPIER > FUNCTION > CST > C3-STMTR
    COPIER > FUNCTION > CST > C3-A4R
    Register the paper width basic value for cassette 3.
    =Place STMTR paper in the cassette 3, and move the side guide plate to suit the STMTR width.
    =Select C3-STMTR in service mode to highlight, and press the OK key so that adjustment will be executed and the value will be registered automatically--
    <Procedure>
    1) Place paper in the cassette, and adjust the side guide plate to suit the width of the paper.
    2) Select the item, and press the OK key. The value will be registered at the end of the adjustment.
    Notes:
    If fine-adjustment is needed after registration of the basic value, use ADJUST > CST-ADJ > C3-STMTR, C3-A4R, CR-STMTR, C4-
    A4R.
