ir 2530 finisher err e716
  • Gleq
    • Feb 2007
    • 72
    Hi
    Am installing a new copier canon ir 2530 after switching on the machine shows e 000716
    Av check all cables. Any ideas
  • mramlawi
    • Jul 2011
    • 838
    Re: ir 2530 finisher err e716
    the finisher theres a lock located on the right of the finisher where the paper tryin to enter it , this lock when you install the finisher puting on it a red belt ,remove it must solve the problem also ,make sure that you connected the cable and power supply for the finisher
    Distinguished road makes you jewel in rough
    • Gleq
      • Feb 2007
      • 72
      Thanks sir
      I removed all the locks and also installed the power supply
      Now the bin moved up and didn't move down. And the machine will show the error E 000716
      and also want to find out if the double cassette models has something to do with the error
      • teckat
        • 16083
        Originally posted by Gleq
        Hi
        e716=which indicates a problem with the communication between the machine and the cassette pedestal or the two-way unit.
        Were the connectors checked & re-seated. > check on The DC Controller, Cassette Pedestal Driver PCB and the 2-way unit driver PCB
        Try disconnecting Cassette Feeding unit > & power up printer
        Cut all of the tie wraps on the light blue wiring harness that goes from the cassette pedestal to the machine. The harness is shown in the picture below.
        • Gleq
          • Feb 2007
          • 72
          Thanks sir
          I wil go back check it and update U.
          The machine came without a pedestal. Can that be the problem?
          and also where can you locate the 2-way unit driver pcb
          Thanks once again
          • magdygeorge1
            • Jan 2013
            • 1
            Thanks sir
            Thanks once again
            The second cassette called pedestal. just remove all connectors comes from second cassette. if it solve your problem then replace the second cassette driver pcb. Regards.
            • ts-lx
              • May 2011
              • 59
              Remove second cartons of OK, I have more than one, can not solve, so the board changed will not work, change line should be good, but no parts
              • teckat
                • 16083
