Canon C4080i Scan Option setting??
  • Dave Braman
    • Mar 2011
    • 16
    I think my C4080i can scan, BUT... Is there a setting in service mode that will enable the "SCAN" button to be available??
    At this piont, there is none shown on the user screen??
    Thank You
    Dave
  • Rachid.Akli
    • Oct 2011
    • 595
    Service mode > Copier > Option > Body > UI-RSCAN : 0=Don't display the scan, 1=Display.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • KL568
      _
      • Feb 2011
      • 324
      Re: Canon C4080i Scan Option setting??
      Hi,Would not "i" in 4080i signify that it has a tab "Send"? This will allow scan documents as PDF/TIFF/JPEG file into a shared folder in PC."Scan" tab will require a Canon TWAIN scanner driver known as "Network Scangear" installed in a PC to detect your machine's scanner, plus another software that support TWAIN scanning.
      • vigour
        • Aug 2010
        • 1038
        I think you are correct but the tab can be turned off or on with UI-RScan as said in the first reply
        • teckat
          • 16092
          I believe this setting is in Level 2 of service mode -hit add function (*)#(2)key after u are in level 1
          - UI-COPY: whether to display the Copy screen
          - UI-BOX: whether to display the Box screen
          - UI-SEND: whether to display the Send screen
          - UI-FAX: whether to display the FAX screen
          - UI-PRINT: whether to display the Print job screen
          - UI-RSCAN: whether to display the Scanner screen
          - UI-EPRNT: whether to display the Expansion print screen (EFI print screen)
          - UI-WEB: whether to display the Web browser screen
          • assets
            • Oct 2012
            • 14
            As a sideways issue you need to set up a fake email address for the machine to SEND. Something like 4080i@mysite.com. Remember it will not receive. You can import your address book but thats another topic.
