Paper Deck W1 IR 7105
  • manuelubau
    • Aug 2011
    • 62
    Just got an used Paper Deck W1 for IR 7105. I pluged it to the machine but the paper doesn't go up? could it be the motor?
    Thanks,
  • teckat
    • 16083
    Re: Paper Deck W1 IR 7105
    Thanks,
    does printer see w-1 deck on panel
    remove panels/ check if lift cable popped off//also check the deck molex connector--remove cover>check inside connectors> they become unseated
    Deck-W1.pdf
    • manuelubau
      • Aug 2011
      • 62
      [ATTACH]17433[/ATTACH]
      Yeah it shows deck on panel... but it just says that it is out of paper...
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5018
        The deck lifter fails to move up (side paper deck)
        Side paper deck
        1) It the deck mounted correctly?
        NO: Mount the deck correctly.
        Lifter cable
        2) Is the lifter cable strung correctly?
        NO: String the lifter cable correctly.
        Spring, Lever
        3) Push up the pickup roller releasing lever with your finger. Does the pickup roller move down?
        NO: Remove the pickup assembly, and check the spring and lever.
        Deck lifter motor (M102)
        4) Does the deck lifter motor rotate?
        YES: Go to step 6.
        Deck lifter driver PCB, Deck open detecting switch (SW101)
        5) Does the voltage between J109-3 on the side deck driver PCB and GND (-) change from about 0 to 5 V when the deck is closed?
        NO: Replace the side deck driver PCB.
        YES: Check the wiring up to the switch; if normal, replace the switch.
        Deck lifer lower limit switch (SW102), Side deck driver PCB
        6) Is the voltage between J107-8 (-) note side deck driver PCB and GND (-) as follows?
        - When the deck is opened, 0 V.
        - When the deck is closed, 5 V.
        YES: Check the lever and wiring; if normal, replace the sensor.
