1570f
  • PANG
    • 104
    1570f
    Hi ! i need some information to reset this model when machine having problem ? Thank you!
  • teckat
    • 16092
    Re: 1570f
    reset from what >>>>>>>>>>>>errors/jams
    u need to investigate the error or jam before clearing-
    PRINT RESET
    Use it to reset the printer; or, use it to clear service error 'E000'.
    this printer has = E-error codes, Fax error codes, User errors, Service error codes--
    suggest u get a manual for product
    • PANG
      • 104
      Re: 1570f
      PRINT RESET
      when i on machine ,the MPT tray up and down a few time and its stop , there is a red light on (IN USE/MEMORY) on control panel , ACTUALLY I NEED TO KNOW HOW TO RESET IT .THANKS FOR ANY INPUT
      • teckat
        • 16092
        Re: 1570f
        FAX FUNCTION
        In Use/Memory Lamp
        It goes ON when an original has been read, a delayed fax transmission has been selected, or memory reception has been used. Further, it flashes while fax transmission is under way.
        Click the "Menu" button.
        Press the arrow buttons to scroll through the options on the screen. Select "MEMORY REFERENCE" and click "Start/Copy."
        Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
        Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine memory-
        Click "Stop" to finish.
        To clear only some documents from memory,
        click "#" instead of "*" in Step 4.
        Follow the instructions to select the documents you wish to delete.
        • PANG
          • 104
          Re: 1570f
          FAX FUNCTION
          In Use/Memory Lamp
          sorry brother, i can t find 'MENU'on control panel, what i see only additional function button and function button, if u don mind can u give me more detailed.. / THANKS
          • teckat
            • 16092
            Re: 1570f
            sorry, posted for wrong model----
            • teckat
              • 16092
              Re: 1570f
              this should do it---
              Press the Additional Functions key
              Press the # key on the user mode menu
              Select Menu Item
              #7 PRINTER (printer function setting)
              scroll to >>>>>
              #4 PRINT RESET
              #4 PRINTER RESET YES= (<) NO= (>)
              Press the Stop key/Additional Functions key to end service mode.
              • PANG
                • 104
                Re: 1570f
                Select Menu Item
                scroll to >>>>>
                #4 PRINT RESET
                if i select'yes' it show#5mlt cleaning but if i select'no" it show#1sssw look like i cant enter yes or no...
                • teckat
                  • 16092
                  Re: 1570f
                  To select the SW number in #1 SSSW of #7 PRINTER, use Paper Select key and Enlarge/Reduce key. To select a bit, use the Left or Right Arrow key.
