IR5570: Solid background and ERR 0061-0002
  • zibros
    • Sep 2012
    • 31
    I have a problem with my Ir5570.
    Firstly, occurred while print out from my computer. There is a solid background (see attachment), but not in copy is normal.
    Because I confused by this, I did to go to *28* COPIER, FUNCTION, CLEAR from ERR to MN-CON. This step is successfully to make all systems normal again.
    About 10,000 copies from above events, the problem arises again and not only for printing but also copying, and E061-002. Then I did the above step again and back normal.
    I think, I did not do something smart, because with the above steps, I changed my personal settings, so I have to set them again.
    I need advice. Does anybody have the same problem? and how to solve this problem with a smart and simple? and exactly, what happened to my machine?
    Z
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: IR5570: Solid background and ERR 0061-0002
    Start with:
    Corona maintenance
    inspect video board
    Simple enough?
    • zibros
      • Sep 2012
      • 31
      Originally posted by zoraldinho
      Start with:
      Corona maintenance
      inspect video board
      Simple enough?
      Thanks for your respons, I always do maintanance to carona. for video board never, could you advice me how, where is it the the video board in machine. I have electronic the manual for ir5570 but i don't find the video board location.
      In addition, when I do a scan on a mailbox no problem, the normal page, but when printed the results like that I attached
      • zoraldinho
        • Mar 2008
        • 5017
        My mistake.Video board is on ir5055.
        E061
        Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
        PCB is faulty. The DC controller PCB is faulty.
        Mode of
        Detection
        0001 As the result of potential control, the drum surface potential (VL2)
        of the white background is about 200 V (generating solid black images).
        0002 The primary charging output used for print output and the drum
        surface potential after laser output has been made are about 200 V
        • Rachid.Akli
          • Oct 2011
          • 595
          Hi,
          What are the values of : Vdt , Vdm , VLt and VLm (In Service mode > Copier > Display > Dpot).
          Rachid.
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • zibros
            • Sep 2012
            • 31
            Originally posted by Rachid.Akli
            Hi,
            Rachid.
            When the occurred the problem, sorry, I don't check those, now is normal after CLEAR
            These are the value for NOW
            dpot-k = 0 v
            vl1t = 60 v
            vl1m = 120 v
            vl2m = 69 v
            vdt = 370 v,
            vdm = 371 v,
            vl1m-p = 67 v
            vl1t-p = 60 v,
            vdm-p = 368 v,
            vdt-p = 370 v
            Could you explain me, what is indicated by the value that related to the problem above?
            thanks
            • COPIERTEC ASSOCIATES
              • Aug 2011
              • 279
              If you cleared MN-CON,it is most probable that the settings for the drum potential are distorted and hence the re-occurrance of the said error.Try to go to COPIER>OPTION>BODY set PO-CNT to 1 if the reading is 0,or set to 0 if the reading is 1.
              • zibros
                • Sep 2012
                • 31
                Thanks,
                I will do your advice next time, if I find same problem again.
                • Rachid.Akli
                  • Oct 2011
                  • 595
                  vl1t = 60 v : This is the reference value of the drum potential after being discharched by the laser.
                  vl1m = 120 v: This is the measured value of the drum pot. after being discharged by the laser. In operating conditions, this value is close to VL1t. It's not your case.
                  If i remember well, in this machine model iR5570 (it is the case of iR5055 and iR5000), the laser beam lights the drum surface that will not receive toner.
                  As a conclusion, i would say that your laser is either dirty or out of service.
                  Rachid.
                  • zibros
                    • Sep 2012
                    • 31
                    Rachid.
                    Thanks Rachid.
                    I think this is a good suggestion for me
