CLC4000 Cleaning Blades
  • FixingMagic
    • Sep 2012
    • 12
    [Misc] CLC4000 Cleaning Blades
    Hi, I'm having trouble with some cleaning blades that are OEM. The manufacture code is FB6-5717-000. The trouble I'm having is that there are lines across the top and the bottom of the page. Would you happen to know if it's the blades?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: CLC4000 Cleaning Blades
    Post a picture please.
    • teckat
      • 16083
      how old are the cleaning units ??
      what color are lines ????
      Drum Cleaning Blade oscillating disk located within the cleaning unit could have a badly worn surface, which causes the blade to bounce with each disk revolution.
      The disk wear can cause the blade to leave the drum surface.
      check & or replace Primary Corona Wires and Grids
