Canon IR3570
  • Caldo
    • 69
    Canon IR3570
    Hi There,
    I have this problem with our new IR3570 copier, when switching it on the copier's LCD display panel does not light up and nothing is displayed in the panel, after turning it off and on again the panel still does not display anything.
    After leaving it for an hour or more and trying it back on the panel works again, after using it for a while and leaving it the panel automatically switches off by itself, but the power led is still on again turning it off and on it still won't work, so leaving it for another hour or so it will work again.
    Can anyone plis help me out on what i should do?
  • rambo40
    • Oct 2007
    • 21
    Hi,
    What have you tried?Did you remove the panel and check all connections etc??It could be simple as a poor connection.
    • lkrsardis
      • Dec 2007
      • 316
      blank display
      Check J110 on the composite power supply.
      Like the United States Postal Service It's a miracle it works!
