ir6000
  • copicatt
    • Nov 2008
    • 366
    ir6000
    Hey guys, have an ir6000. Kept saying reset unit 1. Found the frame side plug/connector for unit one was broken on both sides. Gonna find pn and order one, but looking for tips one replacing. I have removed the boards/duct and then removed connector. Looks like the middle plug just plugs in but there are 4 wires on the corners. How do i pull them out and install in the new one???? Anyone faced this?
    Thanks!!!
  • mramlawi
    • Jul 2011
    • 838
    Re: ir6000
    remove the unit one and check on the back of it if theres some piece of paper , jammed and you didnt see it also check the bios of the unit , some time the screws drivers didnt pushed well .also remove unit 2 and check it
    regards ,
    ram
    Distinguished road makes you jewel in rough
    • teckat
      • 16083
      Re: ir6000
      Thanks!!!
      pin extractor post a pic
      • copicatt
        • Nov 2008
        • 366
        Re: ir6000
        I will try to get a pic later. I used jb weld for a bandaid and its working, but now duplexer wont kick on. Jamd at entrance in duplex mode. Ive probaly bump a connector or something. One sided works though.Figured people have replaced that connector
        • vigour
          • Aug 2010
          • 1038
          Re: ir6000
          The man says use a pin extractor.
          If you can't find one
          Here is what I saw one of my guys do
          He unplugged the dc wires (easy)
          broke the old connector plastic ends (carefully) where the AC wires are located, with a pair of pliers
          one at a time, inserting them into the correct spot.
          pull on each pin to make sure it stays in.
          If it comes loose, raise the "leaf spring thingy" in the middle higher.
          • copicatt
            • Nov 2008
            • 366
            Re: ir6000
            I didn't realize those were AC lines. are you talking about the 4 wires on the corners? hadn't looked at the schematic yet
            • vigour
              • Aug 2010
              • 1038
              Re: ir6000
              I have never measured one, but I have never seen dc wires that huge
              Also they are Black and White
              • Brian8506
                • 1665
                Re: ir6000
                I did this on a 600 once. The connector is the same. If I remember each of those 4 wires has a little brass tab that you press and the wire pops right out. I used a small flat head. I know the frame side part number is VS1-6328-040 because I may have to replace one due to constant E001 codes that nothing else has repaired. The 040 is important because it determines pin number for this part thus a 40 pin connector.
                • copicatt
                  • Nov 2008
                  • 366
                  Re: ir6000
                  Thanks for the info on the tabs and the PN#.
                  • copicatt
                    • Nov 2008
                    • 366
                    Re: ir6000
                    Alright, still waiting on the connector to come in. Talked to customer today and they told me the machine stopped working again the other day. Shows code e0000061-0001. Bad laser? Or has the connector broken again. Would I get that code????
                    This is a school and they only have two copiers total (but thats their fault)
                    • aco.bk
                      • Sep 2012
                      • 130
                      Re: ir6000
                      code e0000061-0001
                      is primary corona assy.try to replace corona wires!
                      • teckat
                        • 16083
                        Re: ir6000
                        can be caused by the laser assembly not obtaining its proper intensity.
                        how old is Drum ???
                        also check MSW2 (loose or miss-adjusted)>switch
                        e061
                        Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
                        1) A solid black copy means laser is defective.
                        2) A white copy means you should check the Primary corona and HVT.
                        3) A good copy means you should check the Potential sensor PCB.
                        • copicatt
                          • Nov 2008
                          • 366
                          Re: ir6000
                          how old is Drum ???
                          e061
                          great info, thanks!!
                          just odd timing that I had it really disassembled to get to that unit 1 connector. thought maybe I did something (and maybe I did), but didn't touch the laser assembly or hvt.
                          which is MSW2??
                          • teckat
                            • 16083
                            Re: ir6000
                            which is MSW2??
                            Manual door MSW2
                            open/closed detection
                            Detects the state (open/closed) of the manual feed tray cover detection
                            Is the laser shutter mechanism normal?
                            • copicatt
                              • Nov 2008
                              • 366
                              Re: ir6000
                              I found it.......manual feed door open/close switch.
                              I will check it. does it just get out of adjustment? It will probably be a few days before I get back there, so I will research....
                              thanks!
