iRADV5035i Machine displays E100-0300
  • canone
    • Jul 2012
    • 4
    [Error Code] iRADV5035i Machine displays E100-0300
    Actions taken so far:
    new Laserunits
    new DC-PCB
    new Main1 & 2 Controller
    all Cables and Pins checked.
    After Init Rotation the Error comes upand is permanent.
    Any suggestions??
  • teckat
    • 16083
    Re: iRADV5035i Machine displays E100-0300
    new Laserunits
    new DC-PCB
    Any suggestions??
    did u pt back your original settings>
    E100-0300: BD error (laser scanner unit 2) CYAN_BLACK_
    When the Laser Scanner Unit 2 (CBk laser) is started or print operation is processing, if the BD signal cannot be detected after the specified time.
    Scanner Motor (C, Bk)
    • Rachid.Akli
      • Oct 2011
      • 595
      The BD signal cannot be detected when the Laser Scanner Unit 2 (C,Bk laser) is started or print operation is processing.
      This model is equiped with two lasers : Laser Scanner Unit 1 ( left assembly) for Yellow and Magenta and Laser Scanner unit 2 (right assy)for Cyan and black. They've the same number: FM3-5425-000 for iRAC5030/5035. So, take care to replace unit 2 in your case. You can also interchange their position and verify if the error extention has changed.
      Good luck.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • canone
        • Jul 2012
        • 4
        • canonclc
          • 71
          Did you fix this fault .got the same problem .replaced dc con & bk/c laser .also showing error for yellow .
          this is an intermittent fault
          • MFPTech
            • 486
            Hello,
            Has this issue been fixed please?
            I just got a call with exactly the same error - going there in a couple of hours....
            Cheers,
            • Exceltech
              • May 2012
              • 14
              Originally posted by MFPTech
              Hello,
              Cheers,
              Did you ever figure this out? I have a new C5235 with this error. I have already replaced the laser unit.
              intermittent error happens several times a day. I'm stumped, and busy!
              • canon33
                • Jun 2014
                • 65
                Canon has released new firmwarelease to fix this issue. Please update to latest and greatest.
                • Exceltech
                  • May 2012
                  • 14
                  Thanks. I thought the firmware was done by previous tech... Not the case. Firmware was still at 19
                  will confirm when complete.
                  • teckat
                    • 16083
                    swap lasers to see if an error changes over to yellow & magenta
                    latest for that series is v31.01.01
                    E100-0300/ dont' see any update for E100-0300
                    common remedies are checking connections and shutter related inspections
                    • Exceltech
                      • May 2012
                      • 14
                      Originally posted by teckat
                      ver. 19 = from factory ? u sure thought they came shipped with v32.04 in 2009
                      latest is v79.04.02 V2 for the imageRUNNER ADVANCE C5051/ C5045/ C5035/ C5030
                      Sorry ... You'll notice above that it's a c5235 model
                      • canon33
                        • Jun 2014
                        • 65
                        Make sure DC con ver is above 9. I believe it was dccon ver 9 that fixed the intermittent e100
                        • teckat
                          • 16083
                          thanks, correction was posted
                          • Canuck
                            Tech Specialist
                            • 1713
                            I had this on a 5035 about a month ago. I had to replace the harness going from the laser assemblies to the dcon...the one made of little blue wires. It had a crack on the little contact board in the connector. You have to replace the whole harness. Good luck. You can temporarily remove the shutter from the laser assembly to rule out any shutter-not-opening issues.
                            • Canuck
                              Tech Specialist
                              • 1713
                              This is probably the issue....put a piece of electrical tape(couple layers) to prevent arcing
