iR3235 Counter Issue
  • TA_Tech
    • 76
    Hi Every1
    I had a iR3235N with a E248 error code. The manual said replace the main PCB but this did not solve the problem. From there we replaced the Hard drive and this solved the problem with the code. However we were then experiencing a problem where nothing on the panel would work except for the On/Off button. We changed the panel and the problem was still there. Eventually we started taking spares from a brand new machine to test, and discovered that it was the main PCB causing the problem.
    After establishing that the main PCB is causing the problem with the panel, we refitted the "Test" main PCB to the new stock machine, however, when we powered it on, we noted that the new machine's meter reading went up from 35 prints/copies to 37655 prints/copies.... the same as the reading on the device with all the faults. So far we've tried clearing everything under the "clear" area of the service mode, formatted the hard drive and re-installed the system software, and we've replaced the counter PCB but nothing has helped to clear the counter back to 35. Has any of you ever had this, heard of this, have any suggestions or know of any solutions. Appreciate any assistance
  • arielcanon
    • Mar 2012
    • 106
    Re: iR3235 Counter Issue
    I think the procedure when you want to test a main board from a new brand machine is take the counter PCB first, install old counter PCB to a new main board. or you can leave counter PCB on new main board but you should also install soft ID PCB from a new brand machine. use Counter PCB and Soft ID PCB together, don't mix it..
    Learning never ends..
    Never give up, where there is a wheel there is a way..
    • charm5496
      • 2387
      you are going to have to contact Canon and probably send the boards back to engineering so they can wipe them for you.
      • Rachid.Akli
        • Oct 2011
        • 595
        Error code E248: EEPROM error ==> Replace the reader controller PCB.
        As far as i know, this error code has nothing to do with the HD ????
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
