touch screen is not reponding irc 4080
  • mido
    • Nov 2011
    • 176
    Hi to all,
    Touch screen is not responding anymore,
    I have IRC 4080, I have a problem on the touch screen response, the user will not be able to perform any thing on the touch screen correctly,
    Is there any adjustment for the touch screen or needs to be changed??
    Thank you in advanced
  • Canon.Tech
    • Mar 2009
    • 335
    Re: touch screen is not reponding irc 4080
    Or simply replace the touch screen, it is quite cheap FK2-0246
    • DAG COPIERS & COMPUTERS
      • Oct 2010
      • 860
      Originally posted by mido
      Hi to all,
      What happens when you press the RESET button on the control panel, doesn't it reactivate the memory?
      • mido
        • Nov 2011
        • 176
        nothing happened,
        • mido
          • Nov 2011
          • 176
          Hi,
          I checked the ribbon cable, it was ok, when replaced the touch screen, it worked correctly
          thank you for your help
          • mido
            • Nov 2011
            • 176
            Hi,
            I changed the touch screen with new one and working correctly
            thanks
              • Oct 2010
              • 860
              Hi, I changed the touch screen with new one and working correctlythanks
              Thank you too for the feedback. I have also learnt from the post.
              • Canon.Tech
                • Mar 2009
                • 335
                Cool. Its the same touch screen on most of the IR series colour & b/w
                • mido
                  • Nov 2011
                  • 176
                  hi friend canon tech.
                  i noticed that the touch screen consist from the screen display & the upper glass i think it is the sensor, connected by a flat cable to the pcb. that means it worked as a sensor, & the problem
                  from the touching this glass. because the screen is lighting and everything clear.
                  do u agree opinion.
                  thanks
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    Yes the touch panel FK2-0246 sits on top of the LCD screen, they are separate parts (sometimes they do stick together & need parting)
                    I belive it uses light I believe it uses light to work not pressure yes.
                    • Fer
                      • Nov 2009
                      • 267
                      Check for dirt/debris under the sides of the display. If they are stuck between the glass and surrounding cover, they can press the touchcreen at that point and prevent response to pressing anywhere else.
                      • Rvale
                        • 83
                        Hi guys
                        This generation of touch screens (Resistive) consist of two thin conductive layers separated by a thin layer of pressurized air, thats why if you make a hole on the touch schreen, even if its a small one it stops responding and the coordinates are given by the different values on the resistivity on each part of the display, on cold coutries like mine we need to warm up the displays first before adjusting them or just the higer resistivity due low temperature already gives a non responsive display, on Canons sometimes cutting the end bit of the flat cable, like one milimeter already solves the matter.
                        Cheers
