ira 5030i lost both pcl & ufr
  • alex@wocltd.com
    • 430
    as a further update - we have acquired an ira5030i to take on service ,however as per a previous post it appears the ufr11 & pcl options are omitted so all i have is a glorified photocopier - when I go level 3 to check license nothing (ie 0) is listed for both ufr & pcl - have tried formatting and reloading latest f/w to no avail - any ideas? canon uk have drawn a blank......when I check device config no pcl option is listed , but can view the rui etc
  • teckat
    • 16092
    Re: ira 5030i lost both pcl & ufr
    where did u get this printer from???
    did u run a Controller System Error Diagnosis on this printer ??
    did u check Main Controller Pcb 2----memory
    • Fer
      • Nov 2009
      • 267
      Is your Copier > Option > Int-Face > Img-Cont> set to "0" if it had an imagepass attached this value is 3.
      • KL568
        _
        • Feb 2011
        • 324
        Hi, Alex
        There is a setting in Service Mode that might be the cause. Using the "i" button in Service Mode to guide you to look for this settings "Invalidate PDL" or something close to that meaning.
        Hope it helps, cause it don't made any sense that the iRAdvance is without UFRII.
        • KL568
          _
          • Feb 2011
          • 324
          Originally posted by KL568
          Hi, Alex
          Hi, Alex
          Belated info, the setting is at level 1
          Copier > Option > Fnc-sw > invalpdl (default value is 1)
          • alex@wocltd.com
            • 430
            thanks for all the pointers - but conclusion is some how someone has permanently deleted/disabled the licenses , and now have tried a last ditch attempt to install the ps option, lms give me a key but when entered on m/c it states 'the feature required for insatllation is not present' does this need extra memory? cant find any reference anywhere?
            • teckat
              • 16092
              PS Printer Kit-AE1
              Memory A needs to be added when adding Direct Print Kit-H1, PS Printer Kit-AE1 or imagePASS-B1.
              Memory A (SOC memory) has 1GB.
              Memory capacity becomes 1.5GB by adding the option expansion memory for Type B (512MG). Depending on the location, some models introduce 1.5GB for Memory A (SOC memory) as standard.
              • Fer
                • Nov 2009
                • 267
                Could it be, that the PS option, needs the PCL/UFR licence to be installed before?
                • KL568
                  _
                  • Feb 2011
                  • 324
                  Hi,
                  Advance models are unlike iR / iRC, PS kit can be install without PCL option. As Teckat has advise, you need a 512 RAM to be install
