Re: Cannon ImageRunner c3220 not powering up.
power off printer/ pull out wall plug
u need to remove the printer back cover
next be careful of the fan connection--see pic//// don't forget tp plug back in fan wire connector
see memory location pic--
Take out memory-clean ends,\re_seatLeave a comment:
But I only have Canadian dollars :P. Sorry guys another problem occured with the printer; this time it seems to restart when printing. I'm not sure why its doing it, but it didn't do that the last time I printed.Leave a comment:
u mean the Cord
here is our bill of sale for services rendered
DSCN9507 (Medium).jpgLeave a comment:
Thanks guys for your help, I was able to get the wire and it fixed the problem. There was an error code afterwards, but after replugging everything back, it the problem was solved. If there are anymore problems I will let you guys know. Thanks alot.Leave a comment:
or
u can call a Canon Authroized dealer to order/ or call a Copier Service company that services Canons-
some of these companies only do wholesale /call to check
https://www.executivecolor.com/item....m=546279&tab=9
Copier Parts|Used Copier Parts|Discount Copier Parts|CANON CORD, POWER SUPPLY|FH2-7060-000
DSN Products, Inc. *::*Canon*::*GRAPHIC IMAGE RUNNER*::*PLAIN PEDESTAL- C1 120V IRC320 0
if u can't find or purchase/ I have a service company in Maryland,USA that might help u order it
Phone: (240) 232-7495
ENCORE BUSINESS SYSTEMS
IT support | Cannon | Rental | Upper Marlboro | Maryland | DC | PGLeave a comment:
Thanks for the picture, now I know what the cord looks like. But, do you know where I can purchase this cord or do I have to call canon and order it from them? Can I buy it from futureshop or The Source or stores similar to it?Leave a comment:
THIS PLUG GOES FROM PLUG LOWER UNIT TO PRINTER SIDE
FOR Cassette Feeding Unit-X1------------------FH2-7060-000 CORD, POWER 120V
READ PDF---Attached FilesLeave a comment:
FOR Cassette Feeding Unit-X1.JPGLeave a comment:
I don't have that particular cord that plugs to the back and connects to the side of the printer. The pins have a different shape, what is that cord called? So I can buy it.
[ATTACH=CONFIG]18309[/ATTACH][ATTACH=CONFIG]18310[/ATTACH]
Sorry if the quality isn't too good; I used my iphone 3g to take the pictures.
These are the pictures for the ports:
Sorry if the quality isn't too good; I used my iphone 3g to take the pictures.Leave a comment:
You are missing a power cord. On the rear view of machine to the left of where the power cord plugs into the cabinet there are three plug sockets. You should have a short power cord that plugs into one of those three plug sockets (does not matter which one) and goes to a plug socket on the finisher side ( right as viewed in photo) of lower panel of the machine where it sits on the cabinet. This will supply power from the cabinet to the machine.
You are missing a power cord. On the rear view of machine to the left of where the power cord plugs into the cabinet there are three plug sockets. You should have a short power cord that plugs into one of those three plug sockets (does not matter which one) and goes to a plug socket on the finisher side ( right as viewed in photo) of lower panel of the machine where it sits on the cabinet. This will supply power from the cabinet to the machine.Leave a comment:
Lol, I plugged the cord into a wall outlet but still the printer doesn't turn on. I've tried plugging a laptop as well to the outlet and the laptop recharges perfectly. I have also tried other devices as well and they work on the wall outlet. Unfortunately, I don't have a voltage meter to test the voltage.Leave a comment:
