Greetings.
My Canon IR 6000 touch screen stopped working. It light up but did not respond to my touch. So I took it apart to inspect. Many of the mounting screws inside were broken and the pc boards were just floating around loosely. I disconnected and re-connected the two ribbon wires from the LCD screen and unplugged and re-plugged some of the connectors including the one to the round dial that controlls the lightness/darkness of the display screen. Then I remounted and aligned the loose pc boards as best as I could and reassembled the unit. Now the LCD screen works and responds to my touch but I can barely read the screen. It displays lots of of short, light and dark verticle lines across the entire screen and the images are only partially visible. The light/dark controll works fine but display image its self is too light. I'm wondering if somethings too tight or a pinched wire or ribbon? Those ribbon wires are quite delicate so I hate to disturb them too much.
Any clue as to what's going on here or what to try?
Thank you,
Dana Lewis
Thank you,
Dana Lewis
