IRADV7065 with error code 843-0001
  • THUK
    • Jul 2008
    • 195
    Hi has anyone seen a 843 Error code on a Canon IRADV7065 my engineer has been in and swapped around the mains leads but still gets the same problem, just wondering if anyone has seen this.
    thanks in advance.
  • Herrmann
    • Jan 2006
    • 792
    Re: IRADV7065 with error code 843-0001
    E843 means loss of power to the fusing unit, check power cord terminal, especially the right connector on it, maybe its loose or burnt
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • THUK
      • Jul 2008
      • 195
      hi i got this sorted, it was the lower lamp cable had rubbed against a rotating shaft and was shorting out.
      There are two circuit breakers and one was off which causes the 843 error .
