canon
  • nih
    • Aug 2012
    • 46
    [Error Code] canon
    good day guys. please i have this problem with this costumer machine by make canon Ir 2200 that is giving me this error code E000000-0000 please any hep will be grateful thank for your consent.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5009
    Re: canon
    -The fixing film unit is faulty
    -The main thermistor has an open circuit
    -The fixing heater has an open circuit
    -The main power supply PCB is faulty
    -DC controller PCB is faulty
    To reset the error, execute the following in service mode:
    COPIER>FUNCTION>CLEAR>ERR.
    • Rachid.Akli
      • Oct 2011
      • 595
      Re: canon
      -E000: 1 sec after the main power switch is turned on. Or, it does not reach ===>This may occur when the busbar voltage falls below 10% of its optimum value.
      -The door switch may be faulty.
      If you cannot clear the error as proposed by Zoraldinho, start by changing the film assembly (film+resistor) and don't forget to reset the error.
      Rachid
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
