iR 7055 firmware and image quality
  • nogood boyo
    • Mar 2012
    • 156
    So...
    how do i update firmware on a 7055?
    I understand that it can be done on a USB and is pretty straight forward? still, i have never upgraded firmware before and am a little nervous about it.
    also, i have another 7055 that has magenta lines running from lead edge to trail edge (see attached image)... dev unit? Dirty transfer roller?
    It doesn't manifest when printing B&W.
  • teckat
    • 16083
    Re: iR 7055 firmware and image quality
    Ways to load/or update System Software - IRADV
    Content Delivery System: (CDS)
    CDS is a service infrastructure where the system software is pushed to the imageRUNNER ADVANCE
    C9075 PRO/ C9065 PRO/ C7065/ C7055 by ways of the internet.
    Service Support Tool:USB Flash Drive:
    Flashing the System Software by use of a USB Flash Drive is supported.
    U need the the specific USB firmware -----
    USB System Software-When extracting the USB file, it will automatically be placed in the following directory: C:\Canon File Folder\SST System Software Folder\USB Files.
    The File can be moved directly to the USB Flash Drive using standard Windows functions. No other preparation is required.
    Open the folder to show the Series folder>Copy the series folder & HD-Format files to the USB stick and the USB stick is ready for flashing the specific series model.
    Turn on the copier by holding the 2 & 8 keys to place the specific series model to Service
    Mode.
    When Download Mode is displayed on the control panel LCD display, insert the USB stick into the USB slot of the series model.
    When the menu is displayed, follow the instructions indicated.
    REMINDER>> U CAN NOT FORMAT A NEW HDD WITH USB PROCEDURE
    Multiple System Software versions can be placed on a USA Flash Drive. (Note that this depends on the
    USB memory size and the size of the specific System Software.)
    • teckat
      • 16083
      Do a process of elimination
      magenta developing unit, Drum unit and or Toner cartridge
      • Herrmann
        • Jan 2006
        • 792
        Looks like a failing drum. Enter Service-Mode and look into the counters, if the drum units (except BK, which is 500000) are near or over 150000, replace them.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • nogood boyo
          • Mar 2012
          • 156
          i thought the same thing but this machine is pretty new... the entire machine doesn't even have 80 000 prints yet.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            What a surprise! Magenta developer.Read PDF..
            • nogood boyo
              • Mar 2012
              • 156
              toner cartridge?
              • Herrmann
                • Jan 2006
                • 792
                just interchange magenta against cyan drum unit, and see if the error migrates to cyan; if yes--> drum unit, if no---> dev unit or else
                • vigour
                  • Aug 2010
                  • 1038
                  I am finding drum lines showing up early when halftones are printed as in your sample.
                  It will not show up if you run solids.
                  IF the dev has a problem you can see it on the roller.
                  There is usually a white chunk of hardened toner at the S blade.
                  You can take the top off ( 2 screws)
                  take the blade off (2 screws)
                  and scoop out any white chunks you find.
                  • nogood boyo
                    • Mar 2012
                    • 156
                    Mode.
                    I don't have to move the firmware files to the USB via SST?
                    I was told from a service tech to power down the machine, plug in the USB, and restart the machine while holding down the 2 and 8 keys... if i don't do this is there a menu option that prompts me to insert the USB? Do both methods work?
                    • nogood boyo
                      • Mar 2012
                      • 156
                      Sometimes its the simple things... just ended up being the magenta charge roller.
                      • teckat
                        • 16083
                        COLOR HAND.jpgsimple is good
                        note on USB>>>U need the the specific USB firmware -----
                        u then drag models USB Firmware folder into USB stick
