Canon IR ADV C 2020 - Wireless Printing Issues, Wake Up Issues
  • pcernicky
    • Feb 2010
    • 66
    Customer is having problems to print over the wireless network from Apple Mac OS X 10.7 and 10.8. It works and then the following day it comes with errors and no printing. Copier has a wireless module installed and they are not using wired connection to the copier. Copier is in sleep mode and wont wake up to start print. This issue is also when printing from Windows 7 PC desktop that's connected thru USB. It works all day but the following morning after copier is in sleep mode overnight it wont start printing. they have to restart copier to print.
    Any ideas???
    Thank you all.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5001
    Re: Canon IR ADV C 2020 - Wireless Printing Issues, Wake Up Issues
    Install latest firmware and disable energy save(high).
    • pcernicky
      • Feb 2010
      • 66
      I don't have access to the latest firmware. Could you please email me the firmware? Any special instructions for the update?
      Thank you.
        • 16083
        Thank you.
        CDS (Content Delivery System3 methods for using the CDS to update Firmware
        The technician is onsite, enters service mode on the copier, selects the updater and has the machine attach to the CDS where the firmware is brought to the machine and the technician may select a version to apply and manually install the firmware.
        The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect to the CDS to obtain Firmware. The Firmware will reside on the device until such time as a service technician visits the device and manually applies the Firmware.
        The Dealer uses imageWARE Remote to connect to the device and schedule a time where the device will connect with CDS, obtain the firmware and apply it automatically without any intervention of a technician.
          • 16083
          Thank you.
          to add on >>>>try setting Sleep Mode to HIGH
          • pcernicky
            • Feb 2010
            • 66
            Sleep mode is on HIGH already....
              • 16083
              then turn it off/ and update firmware
              sleep mode is a waste/ does not save energy/
              printer functions better if left on 24 all day
              • zoraldinho
                • Mar 2008
                • 5001
                congratulations on 100 rep power.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3945
                  X2!!
                    • 16083
                    • vigour
                      • Aug 2010
                      • 1038
                      X3 !!!
                      • KL568
                        _
                        • Feb 2011
                        • 324
                        X 10! My all-time respected tech support Guru. Where do you find the time & energy to dig up Tech info / hints / part catalog !
                          • 16083
                          an old time tech advised me when i first started>>
                          > save as much info as u can> we now call it MOBILE STORAGE
                          • zoraldinho
                            • Mar 2008
                            • 5001
                            Start with new thread:How much for MOBILE STORAGE DOWNLOAD.
                            • KL568
                              _
                              • Feb 2011
                              • 324
                              If firmware is in one of that download links, the whole community will be flocking there.
