HP CP1215
  • mramlawi
    • Jul 2011
    • 838
    HP CP1215
    Dear all ,
    i have HP laser Color Printer 1215 ,facing a problem on print quality ,the colors not above each other ,i used black only and make test it perfect when i make a color the color didnt get well lines not over the line (Flow) i made too many calibrations nothing work,also i install a new Original Cartiages,nothing work ,any solutions ?
    im working in canon copiers ,so in my experience this occur due toner not original,or the ITB problem,or something in laser board.
    but i need more clearance about this .
    thanks
    Distinguished road makes you jewel in rough
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: HP CP1215
    First make sure you have the latest firmware for the printer. If you print a configuration page under Printer Information you will find the Firmware version or datecode (see the link below for printing the configuration page). The most current version is 20100201 (February 1, 2010). You can find the firmware here
    If you have the most current version of firmware and you are still getting misalignment, also known as color plane registration,and cannot correct it with a calibration you may first need to perform an NVRAM initialization and then perform a calibration. It may take up to 3 calibrations to bring it back in alignment.
    Here is a document that explains the steps for an NVRAM Initialization: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01530306&cc=us&dlc=en&lc=en&jump id=reg_R1002_US...
    Here is a document on how to print a configuration page and perform a calibration: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01530414&tmp_track_link=ot_recdo c/c01530306/en_...
    I hope this helps.
    • mramlawi
      • Jul 2011
      • 838
      Re: HP CP1215
      I hope this helps.
      Hello the link said its not found ?!!!!
      • zoraldinho
        • Mar 2008
        • 5015
        Re: HP CP1215
        For me worked fine
        • JustManuals
          • Jan 2006
          • 9838
          Re: HP CP1215
          Paul@justmanuals.com
          • mramlawi
            • Jul 2011
            • 838
            Re: HP CP1215
            For me worked fine
            thanks anw :S file not found gave :S
