Canon IR2020 - Jams - Replaced lots of parts
  • canon_dumbie
    • Oct 2012
    • 8
    [Jamming] Canon IR2020 - Jams - Replaced lots of parts
    Hello,
    I'm dealing with quite the problematic machine. I have replaced several items and swapped them back and forth including (registration clutch, registration sensor, fuser, tray 2 path sensor, main drive motor, DC control board)
    For starters I'll start with Tray 1, saying that Tray 2 is disconnected from the machine. The paper will stop right before registration or right after registration. I have also gotten the message change paper size a couple different times, as well. The tray does securely close and the size selector is on the proper 8X11 (LTR) setting though I have tried changing the orientation to the "R" direction with no difference. I have swapped the paper for a brand new ream of Spectrum Multi-Use and Quill Multi-Purpose paper. Doing all the "fancy" tricks while loading. The climate at which the paper is kept in is good. Now the environment that the copier itself is in isn't the best. They are a fiberglass manufacturing company and even though the copier is in their office it still gets loaded with Fiberglass dust. I have blown out every sensor that I can find.
    Tray 2 now, Tray 2 will feed into pre-registration and stop sometimes there is a mark from the actuator on the front of the paper. I have check the actuator and it seems to work properly. If Tray 2 makes it past pre-registration it jams same as Tray 1 (right before or right after registration)
    Now the kicker (or so I think)
    Not every single page jams I can get 3 pages, 1 page, or even 7+ pages through. but without a cause that I can find to cause a jam. If the "Change Paper Size" message pops-up it will only spit one out of course.
    I have tried countless times to get the event log to print out but for some reason it won't print a single sheet without jamming.
  • ericang
    • Dec 2010
    • 39
    Re: Canon IR2020 - Jams - Replaced lots of parts
    Please post jam codes.. or images when jam.....
    is hard to understand coz these iR machine cause load of different jam
    • Canon.Tech
      • Mar 2009
      • 335
      • canon_dumbie
        • Oct 2012
        • 8
        I have cleaned all the path rollers several times also including the feed rollers; however I didn't know about the one-way. I will have to look that up. Would you happen to have a Part Number handy?
        • Canon.Tech
          • Mar 2009
          • 335
          Ill send you the manual
          Figure 311 item 11
          • canon_dumbie
            • Oct 2012
            • 8
            Figure 311 item 11
            Item 11 P/N FC6-4348-000 - Rear Clutch Bushing
            Does this sound correct?
            • Canon.Tech
              • Mar 2009
              • 335
              Hi,
              Yes I would try that.
              Unless you have another machne you can take the complete pick unit unit in figure 311 from.
              Does the machine have a high count? as this model is not made for high volume lik the ir2270 series etc.
              • canon_dumbie
                • Oct 2012
                • 8
                Hi,
                I ordered the said part. It doesn't seem to be a one-way just a plastic/teflon bushing. is there another part that you were thinking of being a one-way? I have tried putting the said part in to see if it made any difference. The machine is still broken. It seems that part is only for Tray 1 which we are dealing with problems with both Tray 1 and Tray 2.
                I'm not sure how high the count is believe it to be less than 100,000 clicks.
                • COPIERTEC ASSOCIATES
                  • Aug 2011
                  • 277
                  Sometimes this machine tends to be problematic because of the sensor flag or actuator for that matter just before the registration roller.The sensor flag tends to shorten over time and cause constant jams in that area.A simple modification can solve the problem by slightly increasing the length.
                  Also check on the spring of that flag,over time it tends to weaken, increase the tension of the spring to actuate the sensor flag in time.
                  • canon_dumbie
                    • Oct 2012
                    • 8
                    I have tried tightening up the registration sensor spring. didn't seem to make any difference. Do you know about how many clicks it takes to shorted the acutator? I could try to replace both the actuator and spring if that makes sense, I was figuring with the machine having less than 100,000, if I am remembering correctly i think it has around 30,000. that just seems "young" to have this many problems. but look at the environment.
                    • CanonSco
                      Man About Town
                      • Jul 2010
                      • 368
                      Replace the vertical path roller and post back. 5 minute job and solves a lot of headaches with this machine.
                      Yes, I am a nerd.
                      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
                      • canon_dumbie
                        • Oct 2012
                        • 8
                        Do you have part number?
                          • Aug 2011
                          • 277
                          Try to ascertain whether the black unit holding the transfer roller with the black registration do properly mesh when the door is closed on lefthand side is closed.
                          • Akitu
                            Legendary Frost Spec Tech
                            • Oct 2010
                            • 2596
                            Having similar jamming issues in a 2020i, problem is to replace the feed ass'y or replace the gears with the updated models this machine has to be completely gutted... What a POS. Jam code 0104 from tray 1 with a J1 cassette type.
                            • canon_dumbie
                              • Oct 2012
                              • 8
                              I like the sounds of this on; what would the normal culprit be for improper meshing? hinges?
