Could having the image loop tension incorrect cause the registration from from to back not to be straight like a parallelogram? any idea's
imagerunner 110 image not square
Re: imagerunner 110 image not square
201207231343096855495383_70195de6fd4ea788cc737c85592f4ea7-201207231343097120824456.jpg
Post copy of your image issue**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Using the registration test pattern I can get the center line intrack to line up but both sides end up like the picture. I was thinking maybe the writer position isn't perfectly square?
