clc 4000
  • Luther
    • May 2006
    • 682
    clc 4000
    I have a clc 4000 that for some reason wont let me pull the transfer belt assembly out,i lower the lever and pull and its stuck, is there another release or has anyone seen this before?
  • teckat
    • 16083
    Re: clc 4000
    power off printer>
    lift up hopper>
    release T/B handle>
    see if u can slide out the drum/dev unit ?
    if u can> now try to slide out the T/B Unit while drum/dev unit is out---
    T/B unit may not be sitting on slide rails correct
    • Luther
      • May 2006
      • 682
      Re: clc 4000
      drum unit slides out fine, installed new drums today and when i went to pull the t/b unit it was stuck, ill give that a try tomorrow
      • charm5496
        • 2387
        Re: clc 4000
        sounds like the shipping screws are installed in the ITB frame.
        When you drop down the handle do you see the belt cam down at all or is it still flush with the drums?
        • teckat
          • 16083
          Re: clc 4000
          good point on T/B lock in screws /
          if the T/B cams do not fully rotate when handle is released/
          u will have a headache issue to deal with
          u will then have to remove all Drums/Dev's. completely to inspect that T/B UNIT
