My canon irc3200 gives me yellow background when i make a photocopy but works perfectly when i print...please help..thx
Canon irc 3200 yellow background
jerryjayTags: None
Re: Canon irc 3200 yellow background
your description not accurate ,first of all make sure that you are using Original Toner ,also remove the drum and look under it is theres a yellow powder ? if so change new drum , also what the Drum Life counter ?
if u post a sample will be more easy to give you the suggestion and expectationDistinguished road makes you jewel in roughComment
