canon ir 1210 error e100
  • salmi
    • 11
    having a problem with ir 1210 error code e100 when doing a copy the scanner goes on and stops in the middle of scanning
    anyone have an idea ?
  • vandezo
    I don't know
    • 161
    try replace the LD unit...
    • rambo40
      • Oct 2007
      • 21
      Hi,
      E100 is LASER error.The laser beam is not detected.Maybe its dead.Check wiring on the main controller at the back first.
      • Irish
        • 110
        Check laser shutter actuator on back of drum unit .they get broken and dont open the shutter so E100
        • kwazimoto
          • Jan 2007
          • 199
          Do What Irish Says First In Most Cases That Is What It Is!!!!
