Canon ir1210 --code E245
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Error Code] Canon ir1210 --code E245
    Hi to all
    Machine is displying system error E245
    I tried whit turning machine on whit stop button didn't help, i tried to execute clear>all didn't help, i tried printer reset and didn't help. i tried to remove and return JP1 jumper but all without result !!
    but i have replaced another Pcb assembly that work normaly!! What is the problem, which may be in the original Pcb!
    thank u in advance.
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • teckat
    • 16083
    Re: Canon ir1210 --code E245
    following steps should be taken in troubleshooting an E245 code:
    • Check for a loose connection between the Main Controller and the Counter PCB during a copy run.
    • Check the screw is tight on the Counter PCB.
    • Confirm the machine has been flashed to the latest software.
    • Replacing the Main Controller will resolve the problem if the Counter PCB is working.
    • Defective Counter PCB.
    Counter memory pcb. can now be ordered from Canon (pcb is now not restricted by Canon)If replacing the Counter Memory PCB does not fix an E245, E246 or E247 code, suspect a failed Main Controller PCB (put back the original Counter Memory PCB when replacing the Main Controller PCB).
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      Thank you Dr tecakt was the best reply
      DAMENE ABDEL AZIZ
      DJELFA
