Canon IRC 3200 misfeeding in duplex.
  • tinnyjay
    • Oct 2009
    • 663
    Hello
    When i print in two sided mode,paper comes out from fuser and goes up to delivery path,and when try to reverse it stops between left side delivery path and fuser.I just made a check and everything seems to be ok,
    Can you help me ?
    "Who loves the roses,must also bear thumbs"
  • teckat
    • 16083
    Re: Canon IRC 3200 misfeeding in duplex.
    Originally posted by tinnyjay
    Hello
    Can you help me ?
    are u getting jam codes ?
    Duplex only jams on this model= Replace the Duplex Driver PCB & Fuse PCB at same time
    also check the black delivery rollers on door / they soften up from heat/
    + check for a warped duplex tray
    • tinnyjay
      • Oct 2009
      • 663
      I swapped with another one fuser and duplex unit and still the same.
      • teckat
        • 16083
        what exactly did you swap
        u mean u swapped the problem machine fuser unit & the duplex unit to another 3200 and duplex issue followed it to other working printer ??//
        // or do u mean good parts from other working printer (fuser and duplex unit) have exactly same issue in problem machine ??
        if problem printer DUPLEX unit issue followed to working printer then DULPEX is warped
        if the good DUPLEX unit was swapped to problem printer and issue is same > DUPLEX DRIVER & FUSE PCB are no good
        • Fer
          • Nov 2009
          • 267
          What Teckit says:
          The duplex pcb is burned and the blown the fuse on fuse pcb. Replace them both, or solder a new fuse on the fuse pcb and try if it works now.
          • tinnyjay
            • Oct 2009
            • 663
            I swapped a good fuser and duplex from another machine and put them in my machine and the problem was the same.
            • teckat
              • 16083
              did u try the problem printer's fuser and duplex in the working printer
              OK !
              > so the good fuser and duplex from another machine has same issue
              that only enforces what I told u to do ---
              replace the Duplex Driver PCB & Fuse PCB at same time in the problem printer
              there is a fuse that deteriorates on fuse pcb. >>either FU26 or FU27 or both> mostly on FU27--
              the continuity read across fuse will read good> it's the voltage across them that breaks down-
              on FU27 it must be a constant 5v> issue is when it reads 2.5/3v-constant. / FU26
              all the fuses never completely read as an open(bad) unless caused by a short--to ground-- or motor binding.
              Duplex driver is also effected by this----
              • teckat
                • 16083
                OK !
                issue is usually on FU26 - 24V or FU27 -5v / voltage across drops-is not constant / it affects the Duplex driver also
                v=needs to be exact/
                iR3200/3220/2620
                How to troubleshoot the DC-fuse PCB or a missing voltage in the machine.
                When a overcurrent or a short to ground occurs in the machine such as a motor binding or a wire shorted to the frame of the machine, a fuse on the DC-fuse PCB should open to prevent damage to the machine. The DC-fuse PCB is located in the rear lower left of the machine mounted on the DC-power supply. The circuit diagram for the power distribution is found on page 105 & 106 of the technical reference guide.
                The fuse, voltage, connectors, and the destination of the voltage is listed below.
                Fuse Voltage Connector Destination Connector
                3.3 Volts DC have pink wires
                FU11 3.3vdc J59-1 Power distribution PCB J1502-1
                FU11 3.3vdc J59-2 Power distribution PCB J1502-2
                FU13 3.3vdc J60-3 Power distribution PCB J1501-3
                FU13 3.3vdc J60-4 Power distribution PCB J1501-4
                FU14 3.3vdc J61-5 Fax G3-G4 J560-3
                FU14 3.3vdc J61-6 Fax G3-G4 J560-4
                FU15 3.3vdc J61-7 Fax G3-G4 J560-6
                FU22 3.3vdc J64-9 DC controller J100-9
                FU22 3.3vdc J64-10 DC controller J100-10
                5 Volts DC have brown wires
                FU16 5vdc J61-13 Fax G3-G4 J560-11
                FU17 5vdc J60-1 Power distribution PCB J1501-1
                FU17 5vdc J61-11 Fax G3-G4 J560-9
                FU17 5vdc J61-12 Fax G3-G4 J560-10
                FU23 5vdc J71-5 DC controller J106-1
                FU27 5vdc J68-3 Duplex delivery PCB J440-3
                12 Volts DC have orange wires
                FU12 12vdc J59-5 Power distribution PCB J1502-5
                FU18 12vdc J60-8 Power distribution PCB J1501-8
                FU31 12vdc J64-7 DC controller J100-7
                14 volts DC
                FU32 14vdc J65-1 NO output
                24 Volts DC have red wires
                FU20 24vdc J62-1 H3 Fixing unit J802-4
                FU21 24vdc J64-1 DC controller J100-1
                FU21 24vdc J64-2 DC controller J100-2
                FU24 24vdc J74-1 Power distribution PCB J1509-2
                FU24 24vdc J66-1 Fax PCIP J559-1
                FU25 24vdc J67-2 Reader J565-1
                FU25 24vdc J67-3 Reader J565-2
                FU26 24vdc J68-1 Duplex delivery PCB J440-1
                FU28 24vdc J70-1 HV2 sub PCB J91-1
                FU29 24vdc J70-3 Drum ITB motor J93-1
                • tinnyjay
                  • Oct 2009
                  • 663
                  [QUOTE=teckat;319232]did u try the problem printer's fuser and duplex in the working printer No,in fact!
                  When paper reversed it stops in the entrance of duplex,under the fuser,where is a motor in the left side of duplex.
                  • teckat
                    • 16083
                    [QUOTE=tinnyjay;319250]
                    Final Answer:
                    Fuse Pcb (FG3-2337-000)
                    Duplex Driver Pcb (FG6-9671-000)
                    Duplex Motor-M26 (FH6-1974-020)
                    • Fer
                      • Nov 2009
                      • 267
                      Tinny did ya replace the boards yet? If been there several times, the duplex pcb isn;t powering de duplex motor. Thats my it stops just before is goes underneeth the fuser.
                      I got it working by replaceing both boards or just soldering a new fuse, guess i was lucky a few times.
                      • aroundtown
                        Hi I had the same problem and I replaced Both the Duplex Driver PCB and Fuse PCB at the same time. I also changed the Duplex Motor - M26. I am now getting a paper jam error in the duplexing assembly. There is no paper there and of course i can't print. Any suggestions would be appreciated.
                        [QUOTE=teckat;319263]
                        Final Answer:
                        • teckat
                          • 16083
                          [QUOTE=aroundtown;328927]Hi I had the same problem and I replaced Both the Duplex Driver PCB and Fuse PCB at the same time. I also changed the Duplex Motor - M26. I am now getting a paper jam error in the duplexing assembly. There is no paper there and of course i can't print. Any suggestions would be appreciated.
                          What are the jam codes ?
                          the Duplex Driver PCB harness= FG3-2299-000/ canalso cause issues-
                          u may also have a wrapped duplex guide(bowed from heat)/tray see pics>
                          have replaced many of these
                          bowed guide external delivery= FF6-2116-000
                          or upper duplexing guide warped /FB6-3581-000
                          • aroundtown
                            Hi Please see below- was checking service manual -Could it also be the duplexing sensor?
                            [QUOTE=teckat;328955]
                            [ATTACH=CONFIG]18577[/ATTACH]
                            [ATTACH=CONFIG]18578[/ATTACH]
