Canon IR 6000 ADF scanner dark along one side.
  • ybnews
    • Oct 2008
    • 94
    When copying from the ADF the copies come out with a dark shadow across the bottom inch of the 8 1/2" side of the sheet. If I lighten the exposure it goes away. This does not occur when copying from the glass.
    I suspect the scanner lamp but I'm not sure. Can anyone shine a light on what's going on here and how to remedy?
    Thanks,
    Dana Lewis
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: Canon IR 6000 ADF scanner dark along one side.
    Hello,
    As a first step, clean the different reading parts (reflectors, lamp, reading glass).
    Rachid
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • justinjames0909
      try adjusting adf height, sounds like you have light leaking in on either front or back, hope this helps.
      • Desert Rat
        • May 2008
        • 1089
        I had this problem a couple of years ago. I think it had to do with a setting for the doc feeder. Shading I think.
        Is the image registered on the page correctly?
        You could try a D-Con clear. Just be sure an print out the adjustments. I usually check the door specs against the machine
        before I clear anything. You will have to re-input the settings under adjustments.
        I will have to check a couple of boards where I post.
        DR
