can someone help find out how too fix thix error or what it means this error is from er4080 please thanks e000007-0102
E000007-0102
jorgechiva
Re: E000007-0102
e007-0102 =Pressure belt home position detection error Replace the pressure belt HP sensor. Replace the pressure deviation control motor, and fixing unit
Field repair is now out of the question/ not cost effective any more>>
purchase a refurbish unit online
in other words>>>>>>>>>>>>>>>
if u are a tech> remove fix unit to inspect condition>if poor replace entire unit**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: E000007-0102
In most of recent cases i noticed that this error was caused by a lower pressure belt not moving anymore. This was caused bij a broken gear, placed on the opposite site of the fixing motor. Most of these belts die at 150-180.000 copies.
Does anyone know why they break so early, i recon the older units were lasting 300-350.000 pages. I''m greasing every machine i see now with High Temperature GreaseComment
Re: E000007-0102
we don't even bother to repair in field/
Lost Time + Labor + Customer Frustration/
by the time u remove>investigate>& try to repair with a gear> only to find out it still pops a e007
we stock these refurbish units in parts room/ and on site at customers that have multiple 5180 series printers -
i understand this stock procedure is not available to all small or independent companies or free lance techs - but it's frustrating to spend time on a fix>only to pop that error when u leave
Canon replaced one of those problem gears with a metal one> has not helped 007 errors/
what causes stress on gears is the interior belt damage> the thermoswitch metal face causes plastic coating on interior metal belt roller to peal off an cause binding effect/or a surface split on beltbelt
cut one open sometime to view /if u have a chance
see gear pdf>>>>Attached Files**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
