E020-100 IRC 2380i Fault
  • vamoursly
    • Sep 2011
    • 273
    Hello
    I have a new error, in which I am not familiar with;
    E020-100
    I took a look through the service manual and isolated to;
    E020-010x: outside correction range (upper limit) error 2
    At time of printing, the patch density data of the color in question as determined by ATR control is outside the range of correction (upper limit)
    With yellow the issue, the countermeasures are;
    Check the toner leakage from the toner buffer block within the developing assembly. Replace the patch image reading sensor.
    My thinking at present. The ATR is on the process unit at the front, inspect, clean, test.
    Can anyone tell me were the toner buffer block is, I presume on the yellow drum?
    As always I thank you.
    Vamoursly
  • charm5496
    • 2387
    Re: E020-100 IRC 2380i Fault
    is there any yellow printing at all when you run a test print or auto gradation page?
    you could be missing the drive to the developing unit and there are several articles from Canon on this.
    • vamoursly
      • Sep 2011
      • 273
      Originally posted by charm5496
      is there any yellow printing at all when you run a test print or auto gradation page?you could be missing the drive to the developing unit and there are several articles from Canon on this.
      Just tried an autograd, no yellow at all, no errors on startup.New drum, or is it a drive issue?ThanksV
      • teckat
        • 16083
        Yellow Images are Not Being Produced in Copying or Printing Mode /
        Did u check Test prints for Yellow in PG5 and Test Print PG10
        Is the yellow developer unit rotating
        --- see #1 below
        1-Developing Drive Assembly-check for a broken gear on Y Developer Sleeve Drive Clutch/rear of printer------
        2-CHECK-Primary HVT, Transfer HVT
        3-Swap Laser
        4-DC Controller
        5-check the Y developing assembly
