I have a lot of the imageRunner 2800/3300/3300i/3320i. This machines are great, but i dislike how it senses that the waste toner bottle is full. The bottle has a little window on top and many times before it reaches 1/4 of toner the little window gets dirty with toner.
As a result you will get E019 quite often even though there is more waste toner that can go into the bottle.
I once made a hole into the bottle where the light sensor passes through. It work great. But there is something that tells me that there must be another way to fix this, it is doubtful that Canon will make a mistake like this.
So making a hole will work, but I am eager to find a more elegant solution.
Thank you.
Thank you.
