Imagerunner 2545 black spots in copying and printing
  • montana
    • Aug 2008
    • 392
    hi..i have an issue with canon imagerunner 2545 the copy stained with black spots ...i vacumed and cleaned the entire developing assembly then i put a new genuine bottle of toner cex-v32 ...i entered the service mode and execute the Toner install...after 5minute i printed a report...but it is still the same black
    Dots on a light copy...is there any one seen this...thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Imagerunner 2545 black spots in copying and printing
    Post a picture please.
    • arielcanon
      • Mar 2012
      • 106
      check the occurrence, if the black spots have pitch = 4cm, the problem mostly come from developing cylinder (clean dev cylinder), if the pitch around 9.5cm check drum.
      Learning never ends..
      Never give up, where there is a wheel there is a way..
      • Herostrat
        • Oct 2012
        • 220
        As Arielcanon mentioned above u shuld check the lenght betwen dots and thus determine what is leaving them in proces,it can allso be Fuser roler.
        One of the ways is that u let it pring several papers and then open the doors during the proces,when machine stops it will show u after what roller does dots apear...
        Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
        • mramlawi
          • Jul 2011
          • 838
          Check the Heat Stank which located above the upper of the heater ,in this machines always make this problem when it full in toner
          Distinguished road makes you jewel in rough
          • montana
            • Aug 2008
            • 392
            hi....thank you all gentelmen for reply...i will check and feedback..but there is a notice when i visual check the sleeve magnet roller i can see
            clearly the spots appearing on the surface is it a toner issue???thank you again
            • Rachid.Akli
              • Oct 2011
              • 595
              Hello,
              We also had this issue on different machines on the IR25xx series. It's not a toner issue. In our case, we replaced the developing assembly and used the same hopper and bottle toner and the issue is solved. I couldn't explain this phenomenen. From my point of view, replacing the dev cylinder may be enough.
              Rachid.
              "Find a job you love and you’ll never have to work a day in your life." Nagy's father
              • Herostrat
                • Oct 2012
                • 220
                It culd be greese stain...we practise to inspect developing asembly,meaning we take it out-vacume the sleave(as we see it on assembly)-inspect for greese stains and any iregularity-clean it with alcohol even if it has nothing on-roll it against the cleaner blade-vacum-inspect-clean...and so on untill we are shure it's clean.
                Make shure that cleaning blade doesn't have hardened toner on it,leaving lines on sleave as it rolls...if it does,take it off and clean it with nitro.
                Canon may not use developer (dust),but that doesn't mean that it's developing assembly has no faults,needed to inspect ewery now and then,filth gets over time on to roller sleave and alow less toner to be applyed during the proces,clean with alcohol and "dark will be even darker".
