This copier its displaying inset drum cartridge, the drum
Been inseted, bt the same message keeps on coming
Pleaze help!
Did you ever try to remove the developing unit out and fixed it back? if so, retrace your steps, Most likely there's poor contact... with the metallic leaf springs between this unit and the HV unit.
Check also the contacts where the drum sits. probably not making.
