IR 2020 error change paper size
  • mido
    • Nov 2011
    • 177
    I have a problem in IR 2020, message appears change paper size, while copying from two cassettes and A4 or A4R.
    when copying from bypass tray, it works normally any quantity without any problem,
    I replace the registration clutch, paper pick up, feed and seperation roller but the problem still showing message change paper size,
    Regards to all
    thnx
  • teckat
    • 16083
    Re: IR 2020 error change paper size
    Regards to all
    thnx
    Error 'Change Paper Size' is Displayed
    add an extra wrap to the spring for the Registration Sensor (SR209) flag
    or-----
    Message can also be caused by a broken or misaligned Position Block (shown below-- If the cassette does not seem to be locking into place, this part may be the cause. In some cases, applying pressure to the front of the cassette will temporarily alleviate the problem.
    Position Block - FC6-4357-000
    • mido
      • Nov 2011
      • 177
      or-----
      [ATTACH=CONFIG]17970[/ATTACH]
      thnx to your reply.
      but the problem occurs with the two cassettes
      • teckat
        • 16083
        thnx to your reply.
        Did u add an extra wrap to the spring for the Registration Sensor (SR209) flag /
        check lock block on both cassettes
        • Rachid.Akli
          • Oct 2011
          • 595
          Regards to all
          thnx
          Hi to all,
          iR2020is a two cassettes machine. The issue is common to both cassettes, then, there is a very small probability that the issue is due to a pick up problem. I advise to clean or change the vertical feeding roller.
          Rachid.
          Feeding roller iR2020.pdf
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • Kings
            Steve@Kings
            • Nov 2009
            • 79
            I have had this problem many times and ive found the cause to be the reg sensor flag tip worn.
            Sensor flag Part No FC6-4310-000
            New spring wouldnt hurt either
            Spring part no FC6-4308
            Jobs a goodun
            • Rachid.Akli
              • Oct 2011
              • 595
              Jobs a goodun
              The machine works normally with the bypass!!!!!
              Rachid.
              • teckat
                • 16083
                Rachid.
                adj.
                1. Conforming with, adhering to, or constituting a norm, standard, pattern, level, or type
                manual feed paper does not ARC at Reg roller/timing different from cassette pick-up-
                change paper size message > is after copying
                Cassette Paper sizes are determined by the combinations of the Size Detection Assy switches pushed by the paper size lever./ when tray is pushed in> if tray (lock in place_ jumps out during pic-up miss-read of size takes place> with no jam code > just message
                Intermittently the machine will display " change paper size message ".
                From bypass machine runs with no issues.
                Was a new cassette tried .
                Could be a defective Size Detection Assy. { FM2-3319-000 }
                make sure the Registration Clutch, is in place
                Check for a misaligned Cassette Position Block (lock in place)
                • Kings
                  Steve@Kings
                  • Nov 2009
                  • 79
                  Rachid.
                  Do you find that the display displays the correct paper size and when making an A3 copy it jams.
                  If so it is definatly the reg sensor flag.
                  If it is displaying the correct size paper on the display, surely that rules out size identification.
                  Every time ive had this problem (about 10 times) the bypass works fine and when copying from either cassette
                  it shows change paper size.
                  How many copies has the machine done?
                  • teckat
                    • 16083
                    paper size will display correct on panel/ but if tray is not fully secure in place>
                    when u start printing (during pick-up) it will sometimes shift back and forth from rear Size Detection sw's
                    i have witnessed this a few times, on different models especially on a fully loaded tray
                    • Kings
                      Steve@Kings
                      • Nov 2009
                      • 79
                      [QUOTE=teckat;321451]paper size will display correct on panel/ but if tray is not fully secure in place>
                      i have witnessed this a few times, on different models especially on a fully loaded tray[/QUOTE
                      The thing is is that it is happening on both trays.
                      Should try phisically holding the trays in place and see if it still happens.
                      Still think its reg sensor flag with a worn tip.
                      phisically extend the tip slightly as a tempory maesure to see if it cures it.!
                      • Kings
                        Steve@Kings
                        • Nov 2009
                        • 79
                        • Kings
                          Steve@Kings
                          • Nov 2009
                          • 79
                          • teckat
                            • 16083
                            yeah, flag is probably the issue (worn tip or reaction time(spring)
                            i have seen customers tape close paper trays on some models
                            • mramlawi
                              • Jul 2011
                              • 838
                              Hello
                              it happen also with me today ,ill do as u worte all
                              Distinguished road makes you jewel in rough
