hi, i have a ir3300 hang up at the startup screen. After it finished the startup bar. It hang up with the message wait. I have changed the HDD, cleaned the boot ROM and SDRM, re-sit connectors. Is there other suggestions to solve this problem. Many thanks.
IR3300 won't boot up
Re: IR3300 won't boot up
replace the RAM, main controller or boot rom. These are the only items operating during the initial machine start up and if cleaning did not help then it is time to replace.Accidents don't just happen. They must be carelessly planned. -
do u have a Fiery connected ??
or a paper Deck connected ?
or
disconnect Fax board if installed/power off-on**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
