problem imagePRESS C1
  • Joseph2011
    • Aug 2011
    • 88
    good morning:
    I have a problem with a printer imagePRESS C1 leave white spots in full color prints on thick paper, attached sample.
    I have reviewed the transfer unit and the drum
  • irtek
    • Jun 2009
    • 112
    Re: problem imagePRESS C1
    If that is Letter size paper, by the spacing my first guess would be secondary transfer roller.
    • Joseph2011
      • Aug 2011
      • 88
      Paper is not the metric measure of A4 (210 mm x 297 mm)
      on the secondary transfer roller I've changed by another
      • mark921
        • Dec 2010
        • 110
        You have ruled out the drum, the ITB belt, and the secondary transfer unit...and you say it only does it on heavy stock. What about plain paper...same issue? If not, examine the heavy stock for any signs of dimples or dents.
        Also, spacing does look like secondary transfer roller.
        Does it do it on all colors...or just one? If its just a single color, check the developer roller of the offending color.
