org size detection
  • hachetman
    • Jul 2009
    • 96
    org size detection
    we have a 7095 that keeps detecting 11x17 paper from the glass the doc feeder works fine
    Steve Baker
    hachet1_12@outlook.com
    • 16083
    Re: org size detection
    what size is paper original on glass ?
    CCD Unit
    Check ADF open/closed sensors 1/2
    ADF Being Closed
    No. 1 mirror base: at point of original detection
    scanning lamp: off -> on
    original sensor: original detection operation
    - When the ADF is at 25 deg or lower, the external light within the width of any original is kept out of external light, thus causing the machine to assume the absence of an original at points of external light detection (external light search operation).
    The ADF open/closed sensor (main body) identifies the state as being "closed," and the machine starts original size detection.
    - When the external light search is over, the machine turns on the xenon lamp for the main scanning lamp, and checks the CCD (4 points) for external light. For sub scanning direction, the machine starts to operate the original sensor.
    ADF Fully Closed (8 deg or less)
    scanning lamp: on
    The machine looks for a change in the output level of individual sensors for a period of 2 sec after the ADF open/closed sensor (ADF) has identified the current state as being "closed." The absence of a change in the level causes the machine to assume the presence of an original at the point in question.
    The machine uses the combination of changes in the levels of 5 points to identify the size of the original in question.
    • moicez
      • Aug 2009
      • 41
      The doc feeder maybe dirty or worn out (the part that touches the glass).
      You can also change the detection in common copy settings.
      • bk59
        copier option body sens-cnf level 2 change too 1 bill
