IR 8070 registration Clutch Problem
  • abkonnet
    • Mar 2008
    • 166
    [Electrical] IR 8070 registration Clutch Problem
    The registration clutch does not turning ON, No voltage coming to the Clutch, The clutch is good. How to rectify it.
  • teckat
    • 16083
    Re: IR 8070 registration Clutch Problem
    how did u measure that 24 VU ??
    U first need to start from 13 pin DC Connector A13/pin 5 CL Signal-Pin 4 24VU output>to next 7 pin J198 connector pin 5 CL Signal-Pin 4 24VU >to two pin J200 connector Pin 1 24VU- Pin 2 Reg-CL signal for CL2
    remember that is only supplied during timing for Reg.CL to turn on (VU)
    think i have it right u never know
    did u back check wiring connectors for a short/or wire continuity
    • abkonnet
      • Mar 2008
      • 166
      teckat thanks for the reply, i first remove the clutch and apply 12v separately it works, then i remove the registration assembly and keep it a side then turn on the machine (connecting the connector in its place) then checked by coping, the clutch doesnt turn on, Today going to check the wiring,but it seems no problem in wiring, there may be no voltage from the DC controller PCB, tanks for the connector details, did u know in which connector number, this 24v comes form the DC controller PCB.
      • teckat
        • 16083
        this is from iR8500 Diagram/ should be same circuit on iR8570
        enlarge pdf~~~~~~~~~
        believe it's DC PCB.
        J509>on the J509 A13 side pin 4=24vu/pin 5= Reg_CL
        • abkonnet
          • Mar 2008
          • 166
          The problem is with the connector behind the fixing roller, the pin is bended so it doesn't have a firm contact corrected the pin, now its working.
